feigenw Posted March 29, 2008 Share Posted March 29, 2008 I experience a slight vibration in the front end. This occurs when the car reaches between 50-60 mph. I only experience it when the car is on an inclining or declining road. No problem driving on a flat road at any speed. The tires are in good condition and I have them rotated regularly. I stopped by my local tire dealer and he said a 4 tire rebalance and alignment might solve it. I am trying to avoid a costly process of elimination. Has anyone experience this problem, if so what is the solution ? You have my deepest appreciation. Walter Quote Link to comment Share on other sites More sharing options...
Leighcm Posted March 29, 2008 Share Posted March 29, 2008 Sounds like a wheel balance issue to me. Do you have factory or aftermarket wheels on the car? Do you feel the vibration in the steering wheel or in the seat? Quote Link to comment Share on other sites More sharing options...
feigenw Posted March 30, 2008 Author Share Posted March 30, 2008 Sounds like a wheel balance issue to me. Do you have factory or aftermarket wheels on the car? Do you feel the vibration in the steering wheel or in the seat? I have the factory rims on the car. I feel the vibration in the steering column. What do you think ? Thanks, Walter Quote Link to comment Share on other sites More sharing options...
Leighcm Posted March 30, 2008 Share Posted March 30, 2008 Could be a problem with one of the wheels, or a wear problem with one of the tires, or a balancing issue. Most likely it's a balancing issue as it's only in a short speed range. You won't necessarily need the alignment though. Does the car pull to one side? Quote Link to comment Share on other sites More sharing options...
prof Posted April 2, 2008 Share Posted April 2, 2008 Definately a tire balance issue. How new are the tires? Do they have even wear? When was last time balanced? If normal tire balancing fails to correct the problem, seek out a tire dealer that performs high speed on the car tire balancing. They use a machine that spins up the tire when mounted on your car and they can then balance out any front suspension and tire issues at the same time. Just start making some calls. Quote Link to comment Share on other sites More sharing options...
