cjard Posted February 12, 2006 Share Posted February 12, 2006 as per title.. changing the fluid for the first time since i owned the car, and im wondering where the drain plug is for the transmission? tia Quote Link to comment Share on other sites More sharing options...
DFBonnett Posted February 12, 2006 Share Posted February 12, 2006 as per title.. changing the fluid for the first time since i owned the car, and im wondering where the drain plug is for the transmission? tia It's a plug with a large metric hex slot on the bottom of the oil pan. It likely does not have a washer if it has not been down yet. Get one from Toyota. Torque to 36 ft/lbs when reinstalling. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted February 14, 2006 Share Posted February 14, 2006 Oh...and's a 10 MM socket, by the way. Quote Link to comment Share on other sites More sharing options...
