gchahil Posted November 23, 2005 Share Posted November 23, 2005 The CHECK light on the front panel comes on and then after 2 or 3 days goes off. Then it appears again and stays a couple of days. I found out, using a tool from Auto Zone, that the code is P0401. This code indicates many things. Please advise how to fix the problem and exactly what needs to be changed Quote Link to comment Share on other sites More sharing options...
stevelaw Posted November 25, 2005 Share Posted November 25, 2005 Try cleaning out the EGR valve and see if it stops that code. Don't forget to disconnect the negative and reset that computer. How many miles are on it? Quote Link to comment Share on other sites More sharing options...
gchahil Posted November 29, 2005 Author Share Posted November 29, 2005 The CHECK light on the front panel comes on and then after 2 or 3 days goes off.Then it appears again and stays a couple of days. I found out, using a tool from Auto Zone, that the code is P0401. This code indicates many things. Please advise how to fix the problem and exactly what needs to be changed ← It has about 91000 miles on it. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted December 3, 2005 Share Posted December 3, 2005 Yeah---definitley clean it and see if you get the code to go away. Let the board members know what happens, OK? Quote Link to comment Share on other sites More sharing options...
fidgits Posted December 3, 2005 Share Posted December 3, 2005 yes, please keep us posted. Quote Link to comment Share on other sites More sharing options...
