Yaris Mileage
mflores
:angry: Can't believe it. Over a 1000 views and noone has responded? Either there is not a lot of Yaris out there or else other Yaris drivers are getting less mileage than me. <_<
No experience with Yaris...sorry... :unsure: :( If I'm doing my math right, that sounds like about 40mpg, which is great mileage.
In fact 14.5 kms per liter equals 34mpg which for a Sienna would be great mileage but not for a Yaris with an engine less than half the size of a VAN.
The adversited mileage is 44mpg highway and 32mpg city
As already said, I am getting 34mgp in the highway not the 44 advertised.
Have you been doing all of your scheduled maintenances? What kind of highway driving do you do? High speed?
I bought this 2007 Yaris pre-owned with 23,000 miles in it already. Since then I have done all scheduled maintenance. New air filter, spark plugs calibrated, fuel injectors cleaned.
The one time that gave me 33mpg I drove non-stop for 350kms at 75mph.
Any suggestions? What are the 3 main culprits for high fuel consumption? :unsure:
Speed is a big one...you'll get much better mileage around 60mph than 75mph (lower RPMS = better fuel economy). Maintenance is also big, but it sounds like you've got that covered.
A few things:
Temperature is a factor if you're constantly running vehicle accessories like heat or a/c. If you keep windows closed, especially at higher speeds, you'll get better aerodynamics and better mileage. Don't haul a lot of stuff around in the car...less total weight is better. Make sure your tires are properly inflated.
A few things:
Before I purchase my 2001 Echo , in June of 2000, I researched all I could. Consumer reports showed that long term road tests in cold weather regions proved to shave off about 4 to 8 mpg off the estimated.
I remember driving my echo home from the dealer just over 250 miles on a 1/4 tank. I still average around 32/34 mpg, even after 198,000 miles. I have been very happy!
When I took the baby stroller out of the truck and the car seat out my milage went back up to around 36/38, Amazing what a difference that makes.
  • 5 months later...
I have a 2007 Yaris with 40k. The highest mileage I have gotten is 14.5 kms per litre. Is this average? If not, what could be wrong with it?
New yaris - 500 miles of around town driving - 35 mpg. I have not taken it on any extended trips. I had a 2005, 4 cyl Camry that got a calculated 28.8 mpg over a period of two years and 15,000 miles. A light foot on the throttle and speeds less than 65 mpg will up your mileage.
  • 1 year later...
I drive an 07' Toyota Yaris, and I get about 36mpg highway. I check tires regularly, oil changes every 3 months, and I keep it parked in a garage - which helps with fuel efficiency. You might want to have it looked at because one of the biggest benefits of driving a Yaris is the incredible fuel economy.
