Latest Posts
Showing topics posted in for the last 365 days.
- Today
2019 Toyota Corolla LE, after driving it for awhile, I'll make a stop, when I go to leave it tries to start but won't. Have to wait 30-40 minutes then it will start and run fine again. Has anyone had this issue.
- Yesterday
I usually just use my cell phone (not connected to the Toyota navigation system) but recently I've been using the in-car system. I have a 2021 Highlander and the systems are only similar but not identical. 1. Setup Destinations (It does want to let me put in more than one (1) street number. See Navigation Manual Page 346: You can also put destinations in the Address Book. See page 348. The Address Book can hold more entries than the Preset Destinations list. 2. How to TURN OFF the destination when done using it. Turn off? I assume you mean this turn off guidance to the destination? Good question. The map screen in my 2021 has a red "X" button in the lower right hand corner that stops the guidance. Odd that there's no "stop" function referenced in the 2018 manual. 3. How to turn on Destination ON when needed. You can pull the destinations stored in the Preset Destinations list or from the Address Book. 4. How to delete a destination from the system when NO longer needed. You go to the Preset Destinations list (or Address Book), choose and delete it there. I hope this helps a bit. Good luck with your treatments and be safe.
Hey guys. I need help wit a driveshaft for a 03 Toyota Sequoia sr5. What all years and types will fit a rear will 2 wd Sequoia
After some careful typing I got an account with that website you sent me. LOL still pulling my hair out and I don't have much left. I see NO place sign in on that site.
Genuine Toyota OEM part Fits 2019-2023 RAV4 Trim panel sits directly next to rear left seat Part no: 62556-0R100-C0 Position: Left Other Names: Garnish Rear Seat Side Interior Quarter Panel Trim Panel (Left, Rear) Condition: Used, LIKE NEW Color: BLACK Located in SF Bay Area, Redwood City Shipping additional to lower 48 states PM if interested
- Last week
I just bought a 2025 Camry, and I love it. A very good car for an 81-year-old driver, given all the safety features. But what's with the lack of a clock that the driver can read? I don't see one in the screen just ahead and the one in the infotainment (hate that word) screen is very small and positioned as far from the driver's eye as possible. Has anybody found a way to display the clock better?
The panoramic sunroof is intermittent, and my mechanic doesnt want to work on it, and said to take it to a dealer. I dont want that bill, anyone have issues. It works when it does, and when it doesnt, it doesnt do anything. I hope it's just a switch...anyone have this issue
Toyota echo 05 seat belt light blinking non-stop
Trublu replied to Trublu's topic in Yaris / Echo Club
Just to add a little bit more info... Only time when I remove the gear lever to (R) the light goes OFF even if seat belt is buckled or not. But when I remove the lever to P, D, 2 or L, it starts blinking again continuously. -
Hello, 2022 Camry, had a steel rod that was in he road come up and create a hole. Anyone know what is behind it, I want to make sure there isn't more damage. Also if anyone has any repair ideas please feel free to offer them.
Hi, new member here. I have a 2013 Tacoma basic cab with a 6 foot bed, My question is this, I recently installed a snug top fiberglass cap that's a bit heavy, what would I be able to do to the rear suspension to give it a little bit more lift without adding springs? I'm afraid once I load it it will sag. thanks
I have tried the internet to get the information I want. Here is my needs: How to delete the old addresses that were set up by previous owner. How to enter a new address for a destination I want. How to use the address from the address book to go to a given destination. LOL I have several cars with gps and never learned to use it.
Just purchased an 08 Highlander Limited for my wife and its in great shape. I just cant seem to get the turn by turn to work and it is turned on. Any help will be appreciated. Thank you!
Hello, I'm new here and glad to find this forum. Im having problems with my 1990 Camry LE. New stereo harness has less wires than original. I can get power to new unit but no sound. Reasonably sure all speaker connections are correct. There is a pink/white wire that among others that i cant account for. Suspect it powers an amp. Have looked under driver seat and found a 4”x4” box. Amp? It’s definitely not an electric seat so i rule this out. Have heard toyota put an amp under driver seat in some models that year. can someone please help me with some wiring info. i know that: gray = ignition blue/yellow= battery brown = ground have disregarded electric antenna wire, its broken and replaced with regular one. also believe i have all speaker wires correct too. what is the pink/white wire? What am i missing? any help is greatly appreciated.
- Earlier
My runner doesn't mark the speed on the board and it jerks when I accelerate? Is it the vss sensor? can anybody help me ?
Hi there! Does anyone know where they shift lock release button is on a 2005 Toyota Sequoia. I have searched and searched the internet and the manual. I have found it for Corollas RAV4s and several other models but not the Sequoia. The shifter on the Sequoia is near the steering wheel, unlike the other models where it's in the center console.
The decision of not having Wireless connection to Android Auto is a poor decision Some other Car manufacturers did implement it !!! My next car will have to have this feature!!!
Bought it 1 year ago. 6500 miles. Suddenly it started jwrkijg at around 2000-2500 miles but was running fine when on hybrid engine. Then eventually started jerking a lot at any RPM and finally the check engine light came on. A malfunction in the electronic control of the engine throttle, or automatic transmission has been detected. Contact your Toyota dealer in order to have your vehicle inspected. Here is a video: https://drive.google.com/file/d/1EF4RvCUe3u8uGNS-dwrJth8SpeTVy8pB/view?usp=drivesdk Any idea why?
Is it massively out of alignment? Wonder why this is the case - accident damage possibly?
Hybrid - 19,600 new brake pads / rotors
Toyota Owners Club replied to StefanieJ's topic in Rav 4 Club
I would take it to another garage for a second opinion If there is only 2.5-3.0mm left on them then they will need replacing very soon -
2004 Highlander Climate Control Panel Lights Out
Toyota Owners Club replied to DIYRookie1's topic in Highlander Club
are you sure there is not a dimmer control on the lower part of the dashboard that has been turned down -
Confusion around Toyota Collision Centers
Toyota Owners Club replied to NewToyotaDriver's topic in General Toyota Discussions
I do wonder if it is to do with they are the only ones who can repair hybrid and electric models due to legislation and specialist training on high voltages -
New 2024 Corolla SE Suspension Noise
Toyota Owners Club replied to DJK49's topic in General Toyota Discussions
What brand tyres are you running on the car? -
Dealer only via the VIN number, will be expensive
This is my first time posting so apologies if I mess something up. Recently it has started to make a sort of rattling sound when accelerating/at low speeds. The sound seems to be coming from under the car. I'm fairly new to working on cars and wanted to know if anyone might have an idea as to what it could be. Any help would be greatly appreciated! Thursday at 7-29 PM.m4a
Tire pressure too high for the new car I just got
DJK49 replied to noodle's topic in General Toyota Discussions
I had 40 all around in my new Corolla. On the Internet someone explained that this pressure is set at the factory and has some significance for truck transportation to the dealer. Dealers are supposed to adjust the pressure to that specified on the driver's door. Apparently, many do not do so.
