falconkid Posted November 18, 2005 Share Posted November 18, 2005 Hello all I have a question, i have a 1984 camry that i plan on racing in a local mini stock class,is their somplace i can get a diagram for eliminating all the unnecessary wires on the car.I cant get it to run,it runs for about 5 seconds then dies,i just need to use the injector control,injectors ,and charging system, the charging system is not that important, or is there a carburetor that will fit this engine,1995 cc i need an intake and carb. thanks for your time larry Quote Link to comment Share on other sites More sharing options...
stevelaw Posted November 21, 2005 Share Posted November 21, 2005 I don't know which carb and intake to use, but as for the electrical, every Haynes manual has a wiring diagram in the back. Hello all I have a question, i have a 1984 camry that i plan on racing in a local mini stock class,is their somplace i can get a diagram for eliminating all the unnecessary wires on the car.I cant get it to run,it runs for about 5 seconds then dies,i just need to use the injector control,injectors ,and charging system, the charging system is not that important, or is there a carburetor that will fit this engine,1995 cc i need an intake and carb. thanks for your time larry ← Quote Link to comment Share on other sites More sharing options...
