CorollaSpeed Posted August 3, 2005 Share Posted August 3, 2005 hello again i was wondering if it is possible to change fwd to awd differential, and convert my auto trans to manual. if so, how much alltogether?? thanks Quote Link to comment Share on other sites More sharing options...
fidgits Posted August 4, 2005 Share Posted August 4, 2005 well, lets deal with the second part first... As this is entirley possible. However, you need a compatible gearbox, as well as a complete clutch assembly, servo etc... It would be quite expensive to do. As for the former, well yes, theoretically, you could, but you would need to replace a majority of the running gear - dont forget you would need to cut a new transmission tunnel underneath the car - and as part of the process would need a whole new gearbox, you could do this as well, but it would cost you a lot of money. Fensport have built a 4WD 3s-GTE powered Corrola that has hit 200mph... I personally dont think its worth the investment, when you could buy a Celica GT4 for the money the gearbox change alone would cost.. Quote Link to comment Share on other sites More sharing options...
