hey anyone out there who can help me. i just got a first car and it is a 95 tercel. i am fixing it up by myself and i need to change the spark plugs. i have found 2 but i can't find the other two. can anyone help me out and help me find all 4 spark plugs thanks.
Share this post
Link to post
welcome to the forum
the spark plugs for your 95 tercel are simple ones that can be found at most any parts house
if u need more help let me know
those are great cars
se ya redbud
Share this post
Link to post
se ya redbud
thanks for your help redbud, but i meant where on the car can i find them. i know where 2 are located, but i can't seem to find the other 2.
Share this post
Link to post
sorry about that
you will find the spark plugs on the 1995 tercel
under the coils which is in a row on the very top of the valve cover
losten the small bolr with a 10 mm wrench an twist the coil slightly an lif the coil off the top of the plug
if you have found 2 the other two are to the right or the left of the ones you have found
was there coils attached to the 2 u found
i hope this has helped if u need more help let me know
se ya
redbud
Share this post
Link to post
sorry about that
se ya
redbud
[/quote\
i have found 2 on the top of the valve cover. they are the ones with the bolts. since the beginnning i have had a suspicion that the other two are right next to the ones i found but each time i try to pull them off they are really hard to get out and they are just a rubber coil underneath as well. i tried uploading a pic to show you but it won't let me. thanks for your help man.
Share this post
Link to post
u have found the other 2 , after u loosten the small bolt just twist one way an then the other u should feel the rubber relase from the plug that its attached to an lift as u pull they will come out .
r u telling me that the car only had 2 coils on it ,should have 1 over each spark plug
good luck
se ya
redbud
u may email me at gorghamak@yahoo.com
Share this post
Link to post
i am sorry i had a memory lapse on this car the 1995 tercel has only 2 coil an the other wire off each coil goes to the next plug just lift an twist the rubber boot an u should get to the plug
sorry i fool with so many of these things i forgot
redbud
Share this post
Link to post
Loading...
