Bobby76 Posted February 17 Share Posted February 17 It’s throwing the idle air control valve code. (Don’t remember code #) I can’t find the location of the valve. Is it built into the throttle body or? Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted February 26 Share Posted February 26 It is usually in the throttle body and may need adapting if the revs are low on tickover. This is done through a scan tool with the correct actuator functions However, it would be worth looking for any air leaks in the rubber hoses and intake trunking as this could throw a code Quote Link to comment Share on other sites More sharing options...
