noodle Posted December 10, 2023 Share Posted December 10, 2023 I just checked the manual for the recommended tire pressure for Corolla Cross XLE as 33 psi for both front and rear. Toyota App shows 39 front, 38 and 39 rear. Is this common issue for the new car which I received 10 days ago? Should I reduce them to 33 psi? I read that tire pressure too high will compromise Toyota Safety Sense 3.0. What do you think? Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted December 12, 2023 Share Posted December 12, 2023 I think I would refer to your local dealership on this one as it may have a revised pressure setting and the manual is outdated? Quote Link to comment Share on other sites More sharing options...
mavuy Posted March 20 Share Posted March 20 Yes, let some of the air out. Someone was sloppy filling the tires and put too much in. You can always check the recommended tire pressure for any car by looking at the label in the driver's door jamb. Quote Link to comment Share on other sites More sharing options...
DJK49 Posted Tuesday at 11:19 PM Share Posted Tuesday at 11:19 PM I had 40 all around in my new Corolla. On the Internet someone explained that this pressure is set at the factory and has some significance for truck transportation to the dealer. Dealers are supposed to adjust the pressure to that specified on the driver's door. Apparently, many do not do so. Quote Link to comment Share on other sites More sharing options...
