Wyte1ightnin Posted May 17, 2023 Share Posted May 17, 2023 Can someone help me locate where the input/turbine speed sensor is located on my 2007 Toyota Tacoma? Its automatic. Check engine light is on from code p0717. Please and thank you! Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted May 26, 2023 Share Posted May 26, 2023 Not entirely sure where it is located but I would unplug (with the ignition off) each and every plug I could find on the transmission to look for water or dirt ingress and any corrosion Here is some info on the fault code: https://www.yourmechanic.com/article/p0717-obd-ii-trouble-code-input-turbine-speed-sensor-no-signal Quote Link to comment Share on other sites More sharing options...
