bozrite Posted April 10, 2008 Share Posted April 10, 2008 My 2002 4Runner has an apparent flywheel failure ... starter runs, engine doesn't turn over, starter is good. I am told that this happens in Toyotas, the center bolt circle shears and flywheel then spins freely. Is this something that Toyota would provide any financial help on (car has 100K miles) ...is it a known problem covered by a service bulletin, or should I just bite the bullet and have my mechanic do it for about $700 - $800? Quote Link to comment Share on other sites More sharing options...
Leighcm Posted April 11, 2008 Share Posted April 11, 2008 My 2002 4Runner has an apparent flywheel failure ... starter runs, engine doesn't turn over, starter is good. I am told that this happens in Toyotas, the center bolt circle shears and flywheel then spins freely. Is this something that Toyota would provide any financial help on (car has 100K miles) ...is it a known problem covered by a service bulletin, or should I just bite the bullet and have my mechanic do it for about $700 - $800? That would almost fall under the "normal wear and tear category" because it's a clutch component. I haven't heard of any TSBs that would help, but if there are any, your mileage doesn't help you.... :( Quote Link to comment Share on other sites More sharing options...
