hi just traded up from oa pos 2006 zx3 ford focus to a 1998 corolla with 55,000 miles on it.
need ideas of what to look out for.i have one problem already no heat to floor,guage reads just under middle line . not much heat even where it comes out.also is there supposed to be ahole in the fluid line going to fill glycol? last but not least radio has an 8 track opening but theres a CD button on the radio dash  but i sure cant find anywhere to put a CD? Thankd=s for any help
Hi....welcome to the Club
It could be air in the cooling system and you would need to measure the temperature of all the cooling system components with an infra-red temperature gun (very cheap to buy and use) this will then indicate where there is a cool or hot spot and this could be the air or blockage
Have you looked in the trunk area bolted to one of the side panels?
