RIPPERCBX Posted January 21, 2023 Share Posted January 21, 2023 need ideas of what to look out for.i have one problem already no heat to floor,guage reads just under middle line . not much heat even where it comes out.also is there supposed to be ahole in the fluid line going to fill glycol? last but not least radio has an 8 track opening but theres a CD button on the radio dash but i sure cant find anywhere to put a CD? Thankd=s for any help Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted February 2, 2023 Share Posted February 2, 2023 Hi....welcome to the Club It could be air in the cooling system and you would need to measure the temperature of all the cooling system components with an infra-red temperature gun (very cheap to buy and use) this will then indicate where there is a cool or hot spot and this could be the air or blockage Have you looked in the trunk area bolted to one of the side panels? Quote Link to comment Share on other sites More sharing options...
