gfr92y Posted March 26, 2022 Share Posted March 26, 2022 I didn't think I was a dumb person, but I can't get my head around the 3 motor mounts in my U.S.-built 2007 Camry SE 4-cyl 2.4L 2AZ-FE. It failed inspection because I had a bad front motor mount. Being anal-retentive, I wanted to understand what motor mounts were present and convince myself I was replacing the correct one. I finally did convince myself that the front motor mount was behind the radiator on the LH side about 9 inches away from the battery until the sales rep at Summit Racing insisted the front motor mount on the right side. This destroyed my confidence and sent me looking to figure out how I could have misunderstood the location. Using the diagram below, can someone: Confirm that I have properly named the two side mounts and have the correct Toyota part number for each side mount, and Confirm that I have properly named the front motor mount and identified which of the part numbers is (are) the correct Toyota part number? Thank you very much! gfr92y Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted March 28, 2022 Share Posted March 28, 2022 Hi I would take it that the mount (listed below) is the front mount (as listed in the description) It would also be the one that takes most punishment on acceleration and deceleration due to the engine torque being applied onto this mount. Quote Link to comment Share on other sites More sharing options...
