Marine Vet Posted July 19, 2021 Share Posted July 19, 2021 New Member/1st post. 2d owner of car. Friends with original owner. On the way to work this morning. BRAKE and ABS light comes on. Noticed AC isn't cooling. Stopped for breakfast. On restart all lights off. AC cooling. Same occurs. Get to work open hood and check fuses/relays/wiring all is ok. Notice electric fans aren't working. Get back in, scan gauges. TEMP gauge is bottomed at cold as if car is off. Car is running. ABS/BRAKE still on AC not working. Turn car off. Restart. All dash lights are off/AC is cooling/electric fans are running. Tried every combination of control inputs in parking lot for about five minutes to try to trigger condition again. Would not happen. ANY ideas greatly appreciated. *replaced both front hub bearings and both rear hub bearing assemblies about 6 months ago Quote Link to comment Share on other sites More sharing options...
Avalon 96712 Posted July 19, 2021 Share Posted July 19, 2021 Sounds like a intermittent ground fault. 1) Check, clean and tighten all grounding points; 2) If you don't have a scanner, your local auto parts store will probably run a free diagnostic scan that could pinpoint the problem; 3) – least desirable and most expensive: take it to your local Toyota dealer. They'll do steps 1 and 2 and charge you a small fortune - YMMV. Quote Link to comment Share on other sites More sharing options...
Marine Vet Posted July 19, 2021 Author Share Posted July 19, 2021 I wasn’t clear. All works fine until the ABS light comes on. Then all the things listed stop working. Also discovered the Auto Unlock when trans placed in park goes inop also. If I shut off the engine, wait at least a minute the restart the ABS clears and everything works. I have discovered the ABS faults after about 30 seconds and all stops working again every time. Quote Link to comment Share on other sites More sharing options...
Hugo Gomez Posted October 7, 2022 Share Posted October 7, 2022 Hello Sr. I have the exact same issue on my 07 Avalon, how do you solved your issue? Can you give me a hint? hoping you see this, thanks Quote Link to comment Share on other sites More sharing options...
Umair Mughal Posted January 27 Share Posted January 27 did you get solution this problem? Quote Link to comment Share on other sites More sharing options...
