Shahh Posted August 29, 2020 Share Posted August 29, 2020 2016 camry SE -- So my right hand side running light (lower orange one) is not working when headlights on. HOWEVER* it's working as a flasher (turn signal or hazard) At the same time my rear tail light went out on the right side. A: are they both issues connected to each other? B:do I need to change a fuse because I don't see a fuse for that running light 😄 is it a relay issue? 😧 people also say that it can be the bulb because sometimes the bulb can react differently for different functions. Quote Link to comment Share on other sites More sharing options...
