davidk Posted May 1, 2006 Share Posted May 1, 2006 Need advice. (I'm new, sorry if I'm not posting this in the right place) I own a 2005 Toyota Sienna XLE Limited with parking assist sensors which worked fine until the day after someone bumped my rear end (while I was parked) and one of the sensors has a small dent and scratch on the flat surface. Now I get the constant beeping which the manual identifies as a problem with one of the sensors. My dilemma: I can get a brand new sensor for $130 from my autobody guy, but I'm not sure if replacing the sensor will fix the problem. My Toyota dealer wants to charge me $130 just to look at it. Question: Is there a software program on the Sienna that needs to be reset when the sensor is bumped? Would clearing this program reset the sensor and negate the need for a new sensor? Is there a sure way to test whether the sensor is damaged and needs to be replaced without having to purchase a new sensor and without having to pay my local Toyota dealer $130 just to tell me I need a new sensor and an additional $130 to replace it? Any help would be most appreciated. Quote Link to comment Share on other sites More sharing options...
Leighcm Posted May 1, 2006 Share Posted May 1, 2006 I don't think there's a software program...you'll probably have to replace the sensor. Sorry.... Quote Link to comment Share on other sites More sharing options...
