Driveshaft Torque
Cordoch
I recently bought a '07 Corolla. I will do most of the preventative maintenance myself. Every 15,000 miles requires a re-torque of the drivesahft bolt. As this car is front wheel drive and has a transaxle, does anyone know the bolt location and torque specification? Thanks!
The bolt is located in the center of each wheel hub.
You should see it, when you remove the wheel. It has a bent pin and a cap on it.
Don't know the torque though.
But I suggest not to waste your time. I doubt that it could cause any trouble.
But if you want to...
