All Activity
- Yesterday
som49796 joined the community
- Last week
pauliewantaprius joined the community
Joneskym joined the community
Rich Butler joined the community
Thomasr1950 joined the community
On my 24 Tacoma with the Premium pkg. Is Android auto required to use the voice command on the steering wheel button? I saw a video that shows them not using the button.
TopTenCoach started following Sienna Club
TopTenCoach joined the community
Why is the clock so tiny in the new Camry?
paulo57509 replied to boycerensberger's topic in Camry Club
I have a hard time seeing the warning icons. I've gotten to the point where I've memorized most of them. -
boycerensberger replied to boycerensberger's topic in Camry Club
I've just discovered a clock in the main display (speed, tach, etc.), but it's still small for aged eyes. When I took the car home, I was pretty sure that in this day and age it would be possible to customize the display to my preferences. I would have liked the speedometer a bit bigger and a clock much bigger. The fuel gauge takes up too much real estate and many of the icons are cryptic. Considerable work to be done in this department to bring it up to the performance of my 2016 Hyundai Sonata Hybrid. Still, I love the car. Never had such a smooth ride. -
There should be a way to display the clock in the display between the gauges. -
Predawn Grey that may have been some help if I knew where to watch it. Paulo my wife has a cell phone, but does NOT want to connect it other than just as a phone. We used to use it to navigated in our older car. LOL she is getting old to. Personally I hate cell phones.
swilson9833 started following range
just took delivery of a lightly used (10k miles) of a 2023 bz4x love the car so far EXCEPT..... when i set charge to 100% it only gives me a stated 177 mile range? any idea of what the issue could be ? I am only charging to 80% so i get a whopping 147 miles. help if you have any clue
swilson9833 joined the community
Krzysztof Kuchta joined the community
- Earlier
Dan C. started following 2021 Tundra 4x4 8-Foot Bed, w/ 38 Gallon Gas Tank Size
My 2021 Tundra 4x4 8-Foot Bed is listed as having an upgraded 38 Gallon Tank. When the Gas Gauge is exactly lined up on the "E" line (I've only done this twice), My fill-up takes only 30.5 and 31 .2 Gallons, leaving approximately 6 to 7 Gallons still remaining in the tank. Most Gas Gauges , when pointer is on "E", are designed and calibrated have approximately 1.5 to 2.5 gallons remaining in the Tank. -- a couple of things can be happening here... 1) the Gas Tank capacity is not the advertised 38 Gallons, but possibly, and truly only 32 Gallons. 2) The in-tank fuel gauge sender was not corrected or replaced, at the Toyota factory to compliment the larger footprint, optional 38 Gallon Tank, which leaves the excessive and unused reserve when reaching "E". Furthermore, with my lightweight camper mounted 100% of the time, my Tundra averages 12.7 MPG indicated electronically, and each fill-up results in a displayed range of 409 miles available, which coincides with a 32 gallon tank. A 38 gallon tank would result in a displayed range of 482 miles, IF the electronic sender and gauge are correctly calibrated. Has anybody out there had this experience, or any success with a concrete explanation from Toyota? My solution is to treat my truck as truly having a 32 gallon Tank and NOT the 38 gallon tank that my window sticker indicates. Thanks for any help or guidance!
Dan C. joined the community
KnoxVol joined the community
Poser started following 2024 Grand Highlander Audio
Hello everyone, I'm looking for advice on servicing the rear drum brakes on a 2005 Camry (145k). Since buying it used (107k), the brakes have been soft. I replaced the brake fluid and the front brake pads and rotor, but that didn't help much. When I bought the new drum and shoes and started replacing they were in pretty good condition (compared to new), I replaced them a couple of weeks ago anyway and again didn't feel much improvement. The pedal is still soft and does not brake effectively. I noticed that the handbrake does not work properly (the car rolls even on a slight slope with the handbrake fully applied). At the same time, if you tighten it a couple of clicks, the car starts to brake much better. The auto adjuster worked when I installed it, but after replacing the rear brakes the handbrake worked at least a little, now almost nothing again.
If you go to the dealer, I hope they can help you. I've found that because there are so many ways to operate and use the features, the manuals are really confusing. As far as the manuals go, there are two manuals; 1) Owner's Manual, and 2) Navigation and Multimedia Manual. If you want to try this before going to the dealer for help, you can find the manuals online. I find it's easier to do this on a PC. Click the link then follow the screenshots to find the Navigation and Multimedia Manual. https://www.toyota.com/
Since my initial post, I have accepted a job opportunity in another state and will be relocating. Unfortunately, I cannot bring my 1996 Celica GT 25th Anniversary Edition convertible and must sell it before I move next month. I believe that selling it on my own is the best way to go. What would be a good asking price for this low-mileage (61,500) vehicle in very good condition? Thank you for any advice!!
2013 Highlander (124,000 km) U151F transmission filter. Regarding aftermarket filters, specifically the WIX 58010 ordered from Rockauto. I wanted to relay my experience with this filter change and would be interested to know if others have had it too. There is something wrong with the design or filter media on this filter. It caused my transmission to malfunction and I had to replace the old strainer. The Toyota dealer informs me that these strainers are there for the life of the vehicle and they don’t even appear on their parts diagrams. When I put the original strainer back on, the transmission behaved normally. No missed shifts, flares or cutting out. Before with the WIX filter the car wouldn’t go and I had to stop to let the fluid 'catch up' to the demand. The filter was starving the pump of fluid. Rockauto won't give me a refund and just repeats warranty replacement policies. I think they should also investigate these items and remove them from their catalog for that vehicle (and any other Toyotas they apply to that use strainers) so others don’t have my experience. I’m hoping that no long term damage was caused by this and I will let you know if it has. I only drove the car around the block a few times when it was acting up. Canadian Tire (Parts Source) sells a King-o-Matic filter that looks exactly like the WIX unit (same hard filter media) that I was thinking of replacing the WIX unit with, until I spoke to the dealer. I took the original unit into the Toyota dealer and the parts man had a tech look at it and he confirmed it was the original lifetime strainer and that I should just put it back in. Note too that several other suppliers here in the Ottawa area sell replacement filters and I suspect they are all the same. They look like the original and fit the tranny properly but don't work. I also erased the Transmission Control Module (TCM) memory when the WIX filter was installed and it had no effect on the shifting. The transmission threw codes P0776 and P2714 when I tried to drive it which have disappeared with the original strainer back in. All in all this was a very expensive lesson for a simple maintenance operation, three fluid changes, a new scanner purchase and a bad filter. At least the tranny has pretty clean fluid at this point.
Thanks very much Paulo.
Where did you get that information?? Since I posted the question, I found out there is a seperate user manual for the Navigation system. I have just spent several hours reading each and every page. (over 400 pages) All it did was confuse me. I would think I had what I wanted only to be disappointed. I guess my best option is to take the vehicle to a dealer and have them show me how to use the Nav system. I really do appreciate you help...Thanks very much
Can you post a picture of your dash? Preferably at an angle so we can see across the bottom of the clear, plastic screen. I find it hard to believe that you don't have two stalks at the bottom of it.
2019 Toyota Corolla LE, after driving it for awhile, I'll make a stop, when I go to leave it tries to start but won't. Have to wait 30-40 minutes then it will start and run fine again. Has anyone had this issue.
I usually just use my cell phone (not connected to the Toyota navigation system) but recently I've been using the in-car system. I have a 2021 Highlander and the systems are only similar but not identical. 1. Setup Destinations (It does want to let me put in more than one (1) street number. See Navigation Manual Page 346: You can also put destinations in the Address Book. See page 348. The Address Book can hold more entries than the Preset Destinations list. 2. How to TURN OFF the destination when done using it. Turn off? I assume you mean this turn off guidance to the destination? Good question. The map screen in my 2021 has a red "X" button in the lower right hand corner that stops the guidance. Odd that there's no "stop" function referenced in the 2018 manual. 3. How to turn on Destination ON when needed. You can pull the destinations stored in the Preset Destinations list or from the Address Book. 4. How to delete a destination from the system when NO longer needed. You go to the Preset Destinations list (or Address Book), choose and delete it there. I hope this helps a bit. Good luck with your treatments and be safe.
BTW this is for a 2018 Toyota Highlander.
huffman started following GPS Navigation
LOL New Topic. I have checked the users manual that came with the car and the subjuct is made so complicated I can NOT get thru all the steps I want be able to use. I have also looked at the online user manual (ALL 600+ PAGES ONE PAGE AT A TIME) and as far as I can tell the subject is not even covered. I do NOT even see the subject listed anywhere. If anyone know the page number of the Navigation system (if I missed it). I would sure appreciate knowing the page number. Things I want to be able to do: 1. Setup Destinations (It does want to let me put in more than one (1) street number. 2. How to TURN OFF the destination when done using it. 3. How to turn on Destination ON when needed. 4. How to delete a destination from the system when NO longer needed. I sure would like some help with this subject since I am with the VA and they want to send me all over the east coast for treatment. Thanks
Hey guys. I need help wit a driveshaft for a 03 Toyota Sequoia sr5. What all years and types will fit a rear will 2 wd Sequoia
After some careful typing I got an account with that website you sent me. LOL still pulling my hair out and I don't have much left. I see NO place sign in on that site.
First let me say I did try to creat an account on the website you gave me. The cell phone box still gives me fits for some reason. I even borrowed my wife's cell phone number and it still would NOT let me create an account. Yes I have owners manual: acturally 2 of them (one that came with the car and the one Online). Would you believe they are NO T the same. I called the business that sold me the car and talked to the person that sold us the car and he just lied to me by saying he would come to me and show me how to do all of this. He never showed up. Using the Trip miles is a same thing. I have more issues than I can count. Thanks again for your response
Genuine Toyota OEM part Fits 2019-2023 RAV4 Trim panel sits directly next to rear left seat Part no: 62556-0R100-C0 Position: Left Other Names: Garnish Rear Seat Side Interior Quarter Panel Trim Panel (Left, Rear) Condition: Used, LIKE NEW Color: BLACK Located in SF Bay Area, Redwood City Shipping additional to lower 48 states PM if interested
boycerensberger started following Why is the clock so tiny in the new Camry?
I just bought a 2025 Camry, and I love it. A very good car for an 81-year-old driver, given all the safety features. But what's with the lack of a clock that the driver can read? I don't see one in the screen just ahead and the one in the infotainment (hate that word) screen is very small and positioned as far from the driver's eye as possible. Has anybody found a way to display the clock better?
