robertmaiker Posted August 5, 2020 Share Posted August 5, 2020 2012 Camry SE 2.5, pickup up a certified pre-owned with 147k, has 155k now. Dealing with mild-mod vibration, mostly in drive & reverse at idle Notice some vibe on startup in park also. Vibe during idle in drive went 90-95% away after top dog bone replaced genuine toyota, also did front middle mount with genuine. Trying to find if someone has been able to remove vibe completely, and it was pulleys/tensioner/ belt or mounts. I did two side mounts but with used genuine Toyota. Belt looks to be in very good shape and with fresh transmission flush & filter and full synthetic and genuine toyota filter it's Lexus smooth under acceleration and driving. Most vibe is not in reverse, and key item is AC On- all vibration, AC off- almost no vibration I plan on doing left and right mounts with genuine Toyota just want to find if I should look at belt/ pulleys before doing the last two mounts thanks for reading Quote Link to comment Share on other sites More sharing options...
