drobinbarker Posted January 13, 2012 Share Posted January 13, 2012 Hello: I am brand new here. Glad to find you all. I have a 2003 Solara, with 212,000 miles and it is a wonderful machine. Today I had required major suspension work done: Replacement of Four (4) struts; Replacement of Tie Rod End; Replacement of front brake pads; Front end alignment. Upon acquiring the vehicle at the end of the shop's day, I drove off. At the first traffic light, when I came to a complete stop, I felt the brake pedal very slowly 'travel' all the way to the floor. Concerned I returned to the shop. The mechanic drove it and stated he found nothing wrong with the brakes; and indicated that sometimes with new pad on "old rotors" there can be some movement, or something to that effect. I was told to bring it back tomorrow if the problems continue. Upon driving away I found that each time I came to a stop the same 'soft' pedal was apparent and with consistent foot pressure the brake pedal would slowly yield and go all the way to the floor. Concerned I decided to do a power stop to check the ABS, and I found that the ABS apparently is no longer working as there was no ABS braking sensation/vibration/effect; and the tires actually locked up and screeched on the pavement. The ABS light only came on after I turned off the engine and then moved the key to start the car; and upon the engine starting the ABS light goes out (properly). Can anyone please comment on the apparent cause(s) for these conditions? Thank you. Robin Quote Link to comment Share on other sites More sharing options...
