Brian90638 Posted December 18, 2009 Share Posted December 18, 2009 I own a 1992 Camry, 4cyl, automatic. Directly behind the exhaust manifold there are 2 rubber hoses. The hoses are covered with protective heat covers. The hoses come out of the oil filter mount, travel behind the exhaust manifold, and connect to 2 stainless steel pipes that disappear out of sight toward the drivers side of the engine. I ask because it appears I am getting an oil leak from one of the hoses. I've checked my Haynes repair guide and I can't find them anywhere. What are they for? Quote Link to comment Share on other sites More sharing options...
Brian90638 Posted December 18, 2009 Author Share Posted December 18, 2009 I own a 1992 Camry, 4cyl, automatic. Directly behind the exhaust manifold there are 2 rubber hoses. The hoses are covered with protective heat covers. The hoses come out of the oil filter mount, travel behind the exhaust manifold, and connect to 2 stainless steel pipes that disappear out of sight toward the drivers side of the engine.I ask because it appears I am getting an oil leak from one of the hoses. I've checked my Haynes repair guide and I can't find them anywhere. What are they for? Never mind. I discovered what they are for. Oil cooler lines that contain water. Must not be the source of my oil leak. Quote Link to comment Share on other sites More sharing options...
