1992 Camry 4cyl mystery hoses?
Brian90638
I own a 1992 Camry, 4cyl, automatic. Directly behind the exhaust manifold there are 2 rubber hoses. The hoses are covered with protective heat covers. The hoses come out of the oil filter mount, travel behind the exhaust manifold, and connect to 2 stainless steel pipes that disappear out of sight toward the drivers side of the engine.
I ask because it appears I am getting an oil leak from one of the hoses. I've checked my Haynes repair guide and I can't find them anywhere. What are they for?
Never mind. I discovered what they are for. Oil cooler lines that contain water. Must not be the source of my oil leak.
