Calyps0 Posted December 24, 2022 Share Posted December 24, 2022 Looking for suggestions for: Cosmetic (non-performance/sound altering) Low profile (not Fast and the Furious styled) Exhaust tip options for a new 2023 Camry LE AWD (4 cylinder). Anyone know confirmed 3rd party options or (preferable) OEM options. It should be known that I did order OEM part # 174080V010 from Toyota https://parts.centralfloridatoyota.com/p/Toyota__/Exhaust-Tail-Pipe-Tip/63124381/174080V010.html?referer=parts.toyota.com&machineIDT1=rbezkbhipktqb4pt2gfef1oc However, service manager advised me that he didn't think it would fit the LE exhaust because of the width of the tail pipe was too narrow. It did look like that part was too wide to fit flush.vvThis part was meant from XLE models. He wasn't 100% sure about it, mind you and didn't attempt to put the part on (or even size-it-up). So is what the manager told me true? Do the exhaust widths and lengths vary that much from an LE to an XLE? What are the dimensions (width/length, inlet/outlet) of a 4-cylinder LE? Thanks. Quote Link to comment Share on other sites More sharing options...
