rockerrock Posted November 20, 2007 Share Posted November 20, 2007 Would I be able to swap the heads on a 4A-FE with 4A-GE? What is different on the engines? Would I need a new ECU? Can I swap the cams from a 4A-GE with a 4A-FE? Last but not least, would it be cost effective to swap a 4A-FE with a 4A-GE? Thanks! EDIT Found other posts, should search before posting. Quote Link to comment Share on other sites More sharing options...
RunxZ Posted January 2, 2008 Share Posted January 2, 2008 Would I be able to swap the heads on a 4A-FE with 4A-GE? What is different on the engines? Would I need a new ECU? Can I swap the cams from a 4A-GE with a 4A-FE? Last but not least, would it be cost effective to swap a 4A-FE with a 4A-GE?Thanks! EDIT Found other posts, should search before posting. Nope you cant switch the 4afe head for the 4age. The 4afe head is totally diff from the 4age. Best bet is to boost the 4afe or just swap in a 4age 20v. Check this link for a history of the 4age http://home.clear.net.nz/pages/phil.bradsh...0into%20RWD.htm Quote Link to comment Share on other sites More sharing options...
