paul a Posted January 6, 2007 Share Posted January 6, 2007 I'm doing a brake line exchange from rubber to steel braided and i'm not sure if i can use silicone brake fluid or should i just use dot 3 or 4any help would be great Quote Link to comment Share on other sites More sharing options...
stevelaw Posted January 19, 2007 Share Posted January 19, 2007 If you are using the braided steel brake lines that are lined with PTFE, as some of them are, they are compatible with all brake fluids. I use Valvoline Synpower DOT 3/4. It has a high boiling point. Quote Link to comment Share on other sites More sharing options...
