vermonter Posted November 26, 2006 Share Posted November 26, 2006 I have two Corollas. One is a 94 with a bad engine and a great body, the other is a 93 with a good engine and a badly rusted body. I want to switch engines, but the 94 is a 1.6 liter and the 93 is a 1.8 liter. Does anyone know whether this swap is easy/feasible/crazy? If it's possible, what pitfalls should I be aware of? Thanks... Quote Link to comment Share on other sites More sharing options...
Leighcm Posted November 27, 2006 Share Posted November 27, 2006 I have two Corollas. One is a 94 with a bad engine and a great body, the other is a 93 with a good engine and a badly rusted body. I want to switch engines, but the 94 is a 1.6 liter and the 93 is a 1.8 liter. Does anyone know whether this swap is easy/feasible/crazy? If it's possible, what pitfalls should I be aware of?Thanks... I don't remember exactly what year the bodystyle changed on the Corollas, but I do know the ones in 1995-1996 range had both a 1.6 liter and a 1.8 liter engine available. I imagine it won't be much of a stretch to swap the two motors. It may just bolt right in if you're lucky! Quote Link to comment Share on other sites More sharing options...
ShinmaTsunami Posted December 11, 2006 Share Posted December 11, 2006 I have two Corollas. One is a 94 with a bad engine and a great body, the other is a 93 with a good engine and a badly rusted body. I want to switch engines, but the 94 is a 1.6 liter and the 93 is a 1.8 liter. Does anyone know whether this swap is easy/feasible/crazy? If it's possible, what pitfalls should I be aware of? Thanks... The 93-97 US Spec rollas are basically the same. There are minor differences in the engine bay set up. The best idea is to get a Chilton or Haynes (or better yet, a toyota corolla dealer repair manual disc) and work from there. The 4a and 7a (1.6 and 1.8) are identical bothers (except the displacement and engine size) and should be a direct swap. I would check with the main guy at www.phoenixtuning.com for more details. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted December 14, 2006 Share Posted December 14, 2006 Yeah, but one of those years, I can't remember, there is a different biscuit/engine mount. But I suppose he'd just buy it at a junkyard and then make the swap. Quote Link to comment Share on other sites More sharing options...
