paul a Posted October 30, 2006 Share Posted October 30, 2006 Does anyone know if the cams from a celica will fit in the head of a corolla , and if the vvti will still work the same if i switch out the cams? ;) Quote Link to comment Share on other sites More sharing options...
paul a Posted November 13, 2006 Author Share Posted November 13, 2006 does anyone know the answer or am i just in the dark about this topic? Quote Link to comment Share on other sites More sharing options...
Leighcm Posted November 13, 2006 Share Posted November 13, 2006 I don't know the answer for sure, but my inclination would be to say no...the Celica motor was built in partnership with Yamaha, and I believe a lot of the internals are quite different. Quote Link to comment Share on other sites More sharing options...
fidgits Posted November 13, 2006 Share Posted November 13, 2006 yeah, its not going to fit! Quote Link to comment Share on other sites More sharing options...
ShinmaTsunami Posted December 11, 2006 Share Posted December 11, 2006 Does anyone know if the cams from a celica will fit in the head of a corolla , and if the vvti will still work the same if i switch out the cams? ;) That depends on the engine code. Some Celi's were build with a 4a/7a class engine. If that's the case, then they would fit in the rolla. But they're the same engine, so it would be pointless. Also, if it's a zz class engine, then you'd be better off swapping the whole engine. That is to say, swapping a 2zz-ge from the Celica GT-S with your 1zz-fe. The 2zz had alot more after market options btw. Quote Link to comment Share on other sites More sharing options...
