Yuji Posted July 7, 2020 Share Posted July 7, 2020 Anyone here do their own oil change? If so, curious if you guys have tried heavier oils like 10w40? Quote Link to comment Share on other sites More sharing options...
liandor Posted July 8, 2020 Share Posted July 8, 2020 Quote Just use the factory recommended weight oil and your engine will be fine. Quote Link to comment Share on other sites More sharing options...
Surfer Bill Posted July 13, 2020 Share Posted July 13, 2020 Hi, I stopped going to the dealer and I use this for my 2.5L 2016 Camry https://www.searchforparts.com/oil-change/toyota-2016-camry-2.5l-2ar-fe the dealer refused to put it in so I either do it myself or order and take it to my local mechanic. I don't try other oil weights except for what is recommended for the Camry in the manual. I use this oil because I only change it 1 time per year, been doing it since 2005 when I had a 2001 Camry that was burning up oil for no reason and this synthetic oil solved the issue. Quote Link to comment Share on other sites More sharing options...
