cherrmj Posted July 7, 2020 Share Posted July 7, 2020 Hello, I have an 04 Camry 4 cyl with 230,000. Drives fine and progresses through gears ok as well. Looking for some specific help. Transmission engages in Park and holds the car fine on a hill. My concern is that the center console shifter will move to Neutral or Drive without the key or pressing the button. I had gotten so used to this that I stopped even noticing!! Also, a side note, I need to replace the shifter light. I can not remember when this was not like this. bought the car in 2005. I was reading and youtube and it dawned on me that this is not right or safe although I have never had an issue. Is this something that can be repaired or is a replacement needed. What should I check? Thank you all for any specific advice. Quote Link to comment Share on other sites More sharing options...
