Andre Posted December 5, 2019 Share Posted December 5, 2019 Gas smell from left rear . Seems more present after running engine put UV dye Seem to see traces across rear prop shaft but nothing conclusive using uv light evap canister ? but wrong side, no check engine , no drip on floor , no sign on fuel pump under seat any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted December 6, 2019 Share Posted December 6, 2019 That's an awkward one to trace by the sound of it, I have always found that fuel tends to track across other surfaces and then evaporate without leaving much of a clue where it has come from so can be difficult to track the original source. Maybe worth checking the return fuel flow to ensure the pressure is not too high Quote Link to comment Share on other sites More sharing options...
