Angel Posted August 23, 2017 Share Posted August 23, 2017 Hi all, my name is Angel Morales from Puerto Rico, my first post here. I have a 2002 Camry SE with aftermarket system, a few years ago a music shop cutting the radio harness that come from the ECU. I purchased a pigtail to rebuild the whole thing but some colors doesn't match. Now I want to buy the whole harness in an online store. The problem is, that the all harness I found for sale are from LE trim- no JBL system. My question is : Can I use those harness to connect it to the ECU? Any possibility that can work? Any help will be very appreciated, thanks. Kind regards, Angel Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted August 23, 2017 Share Posted August 23, 2017 Hi Angel...welcome to the Club What exactly is the problem with the aftermarket radio, as most of the ones available on the aftermarket are far superior to the original equipment systems? Cheers, Trevor Quote Link to comment Share on other sites More sharing options...
Angel Posted August 23, 2017 Author Share Posted August 23, 2017 47 minutes ago, Toyota Owners Club said: Hi Angel...welcome to the Club What exactly is the problem with the aftermarket radio, as most of the ones available on the aftermarket are far superior to the original equipment systems? Cheers, Trevor Hi Trevor, Thanks for the welcome The problem is some noise, we did everything to get rid of it. Conclusion, problem with the harness. So we want to rebuild the whole thing. Cheers, Angel Quote Link to comment Share on other sites More sharing options...
Toyota Owners Club Posted August 23, 2017 Share Posted August 23, 2017 you could try insulated the harness....using earth shielding such as tin foil wrapped over with insulation tape but running a wire from the shield to a good chassis earth....tends to work a treat and cuts out all noise Quote Link to comment Share on other sites More sharing options...
Angel Posted August 23, 2017 Author Share Posted August 23, 2017 Yes, we did it. There is a short circuit in some section of the harness. We really want to change the whole harness. 1 Quote Link to comment Share on other sites More sharing options...
