Will 1.8L parts fit on 1.6L engine?
streetz661
I have a question if parts for a 1.8L engine will fit on a 1.6L engine. Im talking about intakes, headers or any other parts and if they do want cant I put on my 1.6L. THanxs I would really appreciate your answers.
Maybe the intake...
But similar to put parts on my 1.6?
The 7a-fe(1.8) and the 4a-fe(1.6) are identical engines (4a family), except the 7a, is almost 200cc larger, and the stroke x bore are different. Other than that, the bolts and whatnot are in the same places. However, I would check your exhaust port sizes to the head before buying headers. But other than that, everything should fit fine. However, it may be beneficial to you to do a whole swap to the 1.8 You can find some at your local junk yards or pick -n -pulls for a decent price. And make sure you pull from a DX.
