I've had a great little Tercel 4WD wagon for 9 Yrs. I do my own mechanics and have kept her in good repair. NOW, however, she's doing something strange: carb-engine overspeed as though the throttle valves are wide open (they were NOT). After tinkering with it for a couple hour it ran normal til next time when I punched it. Float level was OK ! There was lingering vapor in secondary bore but not primary. Has anyone out there had this problem What could do that in a feedback carb system ? Power valve ? Auto accelerator pump ? 2nd fuel cut solenoid ckt. ? Gasket leaks ? How can all that fuel get past closed throttle valves ? Or air (from the bleed valve ?) for that matter ? I hope this isn't like Star Trek and a part of my carb is in another dimension. Thanks in advance, greyghost
Share this post
Link to post
Loading...
