JohnS Posted March 22, 2014 Share Posted March 22, 2014 Can anyone tell me the proper procedure for adjusting the rear drum brakes for a 2004 Corolla? I read somewhere that you just needed to pull the parking brake up several times and this would work the self adjuster. I have worked the parking brake several hundred times and it seems to have had no effect. I just noticed that one cylinder is leaking brake fluid so I am going to have to go back into that wheel and fix that while I am in there I am going to see if the self adjuster is adjusting out at all. If not then I need to know if I am not properly adjusting or if I have not replaced parts correctly. Thanks in advance for replies! Quote Link to comment Share on other sites More sharing options...
