D. Dykstra Posted January 1, 2006 Share Posted January 1, 2006 Bought new air filter and PCV for 2002 Camry, but can't figure out how to install them. Our US made cars install in 10 seconds. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted January 3, 2006 Share Posted January 3, 2006 Your air filter has a small bolt in each corner. They need to be removed, with a 10MM wrench, I believe. Undo them and lift the cover up: the air filter comes right out. You might as well clean out the leaves and any other dirt that's in the bottom of the filter housing while you are at it. Put the new filter in, and put the bolts back in. There is another air filter: it's the cabin air filter inside the glove box. Are you trying to replace that? How many miles are on the 02? I ask because you may be able to get away with cleaning the PCV valve out without replacing it. Quote Link to comment Share on other sites More sharing options...
D. Dykstra Posted May 29, 2006 Author Share Posted May 29, 2006 Bought new air filter and PCV for 2002 Camry, but can't figure out how to install them. Our US made cars install in 10 seconds. Car has 36000 miles on it. Thanks for infor on air filter. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted June 1, 2006 Share Posted June 1, 2006 I'd try cleaning out the PCV valve with Gumout before replacing it. Only 35K on it. Car has 36000 miles on it. Thanks for infor on air filter. Quote Link to comment Share on other sites More sharing options...
