bobliane Posted November 28, 2005 Share Posted November 28, 2005 I have a 2000 Solara V6. My check engine light has recently come on and stays on. The car runs great and there are no other apparent symptoms of a problem. What can cause the light? If the oil and coolant levels are okay, is there any urgency to get the light checked out? I can't afford any major work now and would appreciate any insights you can give me. p.s. (A few months ago I got a valve job on the engine preformed by my dealer.) Quote Link to comment Share on other sites More sharing options...
fidgits Posted November 29, 2005 Share Posted November 29, 2005 It could be something as minor as a sensor not working correctly. But it could be a serious problem, and continuing to drive the car, may make it worse... If you think there is nothing wrong, then you might want to risk it - its up to you. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted November 29, 2005 Share Posted November 29, 2005 Go to an Autozone near you, if there is one, and ask them to pull the code for you. Most of them will do it for free (in the expectation that they will sell you a sensor or something). Some Advance Auto Parts (AAP) will do it for free as well. After you see what the code is, then go from there. Quote Link to comment Share on other sites More sharing options...
kal Posted December 28, 2005 Share Posted December 28, 2005 I had the Check Engine light come on second time. First time it went away after the gas tank cap was tightened. But this time it did not. Toyota recommended take to dealer. Somewhere on the web I found suggestion to unplug the battery and see. I did and the light went away. You might want to try this first. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted December 29, 2005 Share Posted December 29, 2005 Yeah, but you know what? If he has a sensor going bad, the light's just going to come back on anyway. Quote Link to comment Share on other sites More sharing options...
kal Posted January 3, 2006 Share Posted January 3, 2006 Yes you were right...it came on next day...I took it to Advanced Auto Parts and got the Oxygen sensor code PO 135 which I gather is front passenger side..I'll be taking it to the dealer..hope it is covered under the 90 k 7 year warranty I've seen in the Owner's manual. I've owned Toyatas since 91 and feel their quality and reliablity has been going down esp as manufacturing shifted out of Japan. I still have 91 camry which runs fine. Quote Link to comment Share on other sites More sharing options...
lexus Posted January 29, 2006 Share Posted January 29, 2006 the best thing is to take it to the toyota dealer or a place that does major servicing Quote Link to comment Share on other sites More sharing options...
