Goldplat Posted November 24, 2005 Share Posted November 24, 2005 My check engine light is on. When I check the 1996 Toyota Camry four cylinder OBD1 check engine procedure to place a jumper from TE1 to E1 and then turn on the key to the on posistion the check engine light just remains solid - it does not blink to give me what the error code is. Any suggestions what the problem is? I can clear the code by pulling the EFI fuse for the recommended 15 seconds but the check engine light comes back on again after driving it. Quote Link to comment Share on other sites More sharing options...
stevelaw Posted November 25, 2005 Share Posted November 25, 2005 Jumper wire clean? Good continuity? My check engine light is on. When I check the 1996 Toyota Camry four cylinder OBD1 check engine procedure to place a jumper from TE1 to E1 and then turn on the key to the on posistion the check engine light just remains solid - it does not blink to give me what the error code is. Any suggestions what the problem is? I can clear the code by pulling the EFI fuse for the recommended 15 seconds but the check engine light comes back on again after driving it. ← Quote Link to comment Share on other sites More sharing options...
Goldplat Posted November 26, 2005 Author Share Posted November 26, 2005 My check engine light is on. When I check the 1996 Toyota Camry four cylinder OBD1 check engine procedure to place a jumper from TE1 to E1 and then turn on the key to the on posistion the check engine light just remains solid - it does not blink to give me what the error code is. Any suggestions what the problem is? I can clear the code by pulling the EFI fuse for the recommended 15 seconds but the check engine light comes back on again after driving it. ------- After I reset the code and when I test the check engine light it still will not flash even after the code is cleared. Checked with new wire and still the check engine light remains solid during the checking process. Quote Link to comment Share on other sites More sharing options...
