Glovebox noise
Pushmatic
If you've noticed this problem, here's the solution. My son owns a '05 gts which developed a rattle (sounded like a loose washer vibrating on a bolt.). the noise seemed to be coming from behind the glove box. Didn't really notice the noise until about 2500 to 3000 rpm. Anyway, as it turns out the air conditioner lines were transferring engine vibrations into the cabin. The lines run near the passenger shock tower. We put a piece of adhesive backed weather strip between the tower and the lines and this noise vanished. Maybe this will help someone.
Hmmm...I do have a noise like this in my Lexus. Thanks for the tip - I'm going to check this out. Maybe the same rules will apply.....
  • 2 months later...
