avsanjay Posted January 3, 2005 Share Posted January 3, 2005 I have a 2001 corolla with 36,000 miles. It recently had a 30,000 mile service done. The front and back break pads have been replaced with new ones. I have noticed that after the service, whenever i start the engine in the morning, i hear a strange noise/vibration from the front portion of the car. This noise comes, only when the brake pedal is pushed. The noise comes for around 2 to 3 minutes. This happens only when the car is started for the first time in the morning. Any pointers to whatz happening will be appreciated. Thanks Sanjay Quote Link to comment Share on other sites More sharing options...
fidgits Posted January 4, 2005 Share Posted January 4, 2005 If I was you, I would go back to the garage which replaced the brakes, the work should be warrantied, and although you dont say there is any problem except the noise, I would be worried about any problems with that area! Quote Link to comment Share on other sites More sharing options...
bluerolla22 Posted May 14, 2005 Share Posted May 14, 2005 try this i think there is dust on your break pads all you need to do is slam on your breaks at about 10-15 mph 2 to 3 times and see if the noise stops this happened to a friend of mine's car. Quote Link to comment Share on other sites More sharing options...
JoshB Posted May 18, 2005 Share Posted May 18, 2005 try this i think there is dust on your break pads all you need to do is slam on your breaks at about 10-15 mph 2 to 3 times and see if the noise stops this happened to a friend of mine's car. I wouldn't go slamming on your breaks to fix things, as it may only be a temporary fix... I had this same deal in the last car I owned. I installed some cheap breaks, which were very "hard" breaks, and they will most likely always make noise when breaking. Quote Link to comment Share on other sites More sharing options...
Azza Posted May 19, 2005 Share Posted May 19, 2005 Hi Guys, I am new to TOCUS - I am from TOCAU (Australia)... I have an issue with my current Corolla (2004 Corolla Sportivo), and I notice it predominantly when either weather is cool (ie 10 - 20 degrees celcius) or the brakes are wet like when I have either parked outdoors in the rain or just washed the car... I find that by the time I get half way up the street from my house, about 1km, it goes away.... I also had the same problem with my 2000 Corolla Levin. Have never thought anything more of it. The noise usually goes away fairly quickly and the brakes have always worked... Cheers Aaron :) Quote Link to comment Share on other sites More sharing options...
