Moffmo Posted December 24, 2004 Share Posted December 24, 2004 The Differences the main way to tell between a phase 1 and a phase 2 is the headlights, if the hearlights have a teardrop, then it is a phase 1, phase 1 have a SLIGHT one.... The interior in a phase 1 is greyer, and the buttons are rounder, and the dash board (Non TSPORT) has rounder symbols and gauges. The phase 2 has square buttons and squarer gauges...also, the middle section of the dash goes right up to the odometer surround..... on a phase 1, this doesnt reach the odometer surround and is completly different The phase 1 DOES NOT HAVE A BOOT LIGHT Will add more if i can rememer... Why you need to know Well for a start, the bumpers are shaped differently, so some bodykits will only fit phase 1 as apposed to phase 2, this is entirely different for tsports as a body kit for a normal echo will definatly not fit a Tsport.... It will help you to know what phase your yaris is when it comes to adding headunits for example... Hope this helps you all! Quote Link to comment Share on other sites More sharing options...
