Pormoonman Posted September 7, 2011 Share Posted September 7, 2011 Hi, I'm a newby form Winston-Salem, NC. I was looking for a website to give me information in replacing my clutch. Hopefully that will take care of my drive train problem. The car will not move at all. I was driving on the interstate and the engine suddenly revved up and I believe I engaged the clutch to disengage the cruise control and coasted to an exit and was lucky enough to be able to coast into a convenience store parking lot. When the clutch went I saw what appeared to be piece of the clutch in the rear view mirror. I was puzzled about how the clutch material was to get out. Today I found I was able to see the flywheel through a cutout area in the bottom of the engine. I was wondering if that area is supposed to have a cover that is no longer there? Also, I noticed a little oil under the transmission and wondered if I should replace the seal behind the flywheel? Quote Link to comment Share on other sites More sharing options...
redbud Posted September 7, 2011 Share Posted September 7, 2011 welcome to the forum i would reccomend u get a repair manual for this car they have A lot of these on ebay u would save enough on this job to make it worth your while they will tell an show u in detail how to do this job by the way ur probably looking at a 700 dollar job here in tn where i live , different in other parts of the country i hope this helped u some , if i can help u more im good on email se ya redbud Quote Link to comment Share on other sites More sharing options...
Pormoonman Posted September 9, 2011 Author Share Posted September 9, 2011 welcome to the forum i would reccomend u get a repair manual for this car they have A lot of these on ebay u would save enough on this job to make it worth your while they will tell an show u in detail how to do this job by the way ur probably looking at a 700 dollar job here in tn where i live , different in other parts of the country i hope this helped u some , if i can help u more im good on email se ya redbud Quote Link to comment Share on other sites More sharing options...
Pormoonman Posted September 9, 2011 Author Share Posted September 9, 2011 Thanks, I have a Haynes manual. I've done the job before on a Prius. Pormoonman Quote Link to comment Share on other sites More sharing options...
