00 camry transmission failure
ross brooks
I just spent 2800 dollars to completely rebuild my A/T. the diagnosis was catastrophic failure of BOTH differential bearings which caused contamination of the transmission and ultimately Failure. Anyone have any success getting financial help from Toyota USA ? P.S. ALL transmission checks and maintenance at 30K and 60K done at a Toyota dealership. This was my family's 18th toyota in 23 years.. Heretofore, maintenance issues were non existent with toyotas. Reason I kept buying. I have lost the love. Help!! :(
if you had the major 60k service at a Toyota dealer, then I would go back to the dealer who did this, as the 60k should change the fluid, and while if it is not longer under warranty they are not legally bound to help, you may be able to push them to pay some of the bill for not picking up the problem sooner.
  • 14 years later...
