timmyb74 Posted June 11, 2011 Share Posted June 11, 2011 I accidentally drained the ATF fluid fron my Echo instead of the oil. Boy, do I feel dumb. This is the first Toyota I've ever owned and I guess I was in too much of a hurry and opened the first drain plug I found. My question is what kind of ATF fluids should I use to replace what I've drained out and how much will I need? Is this going to cause me to have any problems with the transmission? Quote Link to comment Share on other sites More sharing options...
harvey Posted July 3, 2011 Share Posted July 3, 2011 I have changed 2003 echo also 2005 echo both with automatic transmission the drain volume is 3.2 quarts it is toyota type t-iv caterol Import mult-Vehicle automatic transmission fluid meets toyota type T, t-III & T-IV note the 2003 echo was type T the 2005 was type T-IV.you also need to replace washer on drain plug it alum. hope this helps. Quote Link to comment Share on other sites More sharing options...
