ntanimo Posted November 9, 2010 Share Posted November 9, 2010 How can I restore fuel efficency in my 2003 camry? Quote Link to comment Share on other sites More sharing options...
humanoid Posted November 9, 2010 Share Posted November 9, 2010 What's your current miles/kilometers per gallon/liter? Quote Link to comment Share on other sites More sharing options...
ntanimo Posted November 9, 2010 Author Share Posted November 9, 2010 My current mileage is 100k. How do I Calculate mile per gallon? Quote Link to comment Share on other sites More sharing options...
Leighcm Posted November 9, 2010 Share Posted November 9, 2010 1.) Fill up your tank. 2.) Drive until it's fairly low 3.) Fill it back up. 4.) Take the number of miles you drove on that tank, divide it by the number of gallons you just put in. Quote Link to comment Share on other sites More sharing options...
Steve Posted November 9, 2010 Share Posted November 9, 2010 try this site scroll past the adverts http://www.milesgallon.com/ Quote Link to comment Share on other sites More sharing options...
Broadcaster Posted November 10, 2010 Share Posted November 10, 2010 On my Solara SLE V6 for the last 11 years I have been averaging 23.9 mpg in a challenging area like Los Angeles. I don't accelerate as though it is a race, nor do I brake the last minute. I have got accustomed to slow down at traffic lights to such an extend that by the time I arrive to the light the lights have changed or are about to change. This prevents me to come to a total stand still. Moving from total stand still requires the most fuel, so reduction of those situations and awareness of them helps the fuel economy. This also helps with brake pad wear. My pads on average last me 55000 miles. At junctions I slow down to a crawl and then move on. I know that is illegal but in the 11 years here I have only been caught once . $200 ticket has been calculated in the 23.9 mpg. I am not proposing driving through crossroads, but I am saying avoiding to come to a total standstill. Also I am not advocating disregard to the right of way of others in the junction. This additionally also helps with brake pads wear. I am a very careful driver without being dangerous, which means I calculate and compensate for the morons I see every day. I also use the cruise control where ever possible. This reduces un-uniform depression of the accelerator pedal, which contributes to fuel inefficiency. Quote Link to comment Share on other sites More sharing options...
Steve Posted November 10, 2010 Share Posted November 10, 2010 i watched a program the other day about some guy who can double the mpg of any car. It seems this guy recommend building up speed and then coasting... and keep repeating this action. it looked a pile of crap and dangerous, but it did work according to this avg tank mpg reading he doubled the mpg. Some of the tricks were dangerous though and was quite irrisponsible like also turning his engine off when costing which is sheer stupidness. Any car that cruises at 55-60 is going to get the most optimum MPG performance. Quote Link to comment Share on other sites More sharing options...
Leighcm Posted November 10, 2010 Share Posted November 10, 2010 I get about 17mpg at 100.... that seems pretty good... Quote Link to comment Share on other sites More sharing options...
Suicideknob Posted November 24, 2010 Share Posted November 24, 2010 ntanimo, There are so many variables involved in figuring one's MPG average that it's almost impossible to arrive at an accurate figure. A headwind will decrease your mileage a tailwind will increase it. If you're traveling on roads that require you to drive at speeds above 45mph then your mileage will decrease with every MPH you drive above that figure. Every pound of weight you put in your car will eat away at your mileage. That includes people as well as things you put in the trunk. You'll even get less mileage with a full tank of gas than you will when the tanks half empty. Running the air conditioner will cost you about one MPG. Even temperature and road conditions will have an effect. Everything from low tire pressure to a badly tuned engine can change the mileage you're used to seeing. If you're going to check your MPG average, try to keep everything as constant as possible. That's the only way you will come up with a figure that means anything. The surest way I can think of to regain the mileage you got when your car was new is to stop the government from forcing oil companies to put ethanol in the gasoline they sell. There is simply less energy (B.T.U's) in ethanol than there is in gasoline, hence less miles per gallon. Think back, did your mileage seem to drop off around the time that questionable practice was initiated or did something else cause you to notice it? Quote Link to comment Share on other sites More sharing options...
ntanimo Posted December 12, 2010 Author Share Posted December 12, 2010 What's your current miles/kilometers per gallon/liter? My current MPG is 18.9 Quote Link to comment Share on other sites More sharing options...
Cathy Temple Stansell Posted February 7, 2012 Share Posted February 7, 2012 I was getting a good 30+mpg in my 1993 5speed camry! now i have to go to the gas station before i go to the gas station, if you get my jest! Quote Link to comment Share on other sites More sharing options...
Stuart Swanson Posted October 10, 2017 Share Posted October 10, 2017 I always put 2 psi more in the tires than what it says! Helps me! 1 Quote Link to comment Share on other sites More sharing options...
