babykaye Posted May 19, 2005 Share Posted May 19, 2005 my car has it's "check engine" on... is this a maintenance thing or something's wrong with the engine? i'm stupid when it comes to cars... help? Quote Link to comment Share on other sites More sharing options...
fidgits Posted May 19, 2005 Share Posted May 19, 2005 generally this is for when something isnt quite right - such as the airflow sensor getting a null reading.. I would reccomend taking it to the garage to see what is wrong.. Quote Link to comment Share on other sites More sharing options...
lexus Posted January 29, 2006 Share Posted January 29, 2006 take it to the toyota dealer if it ends up costing way to much take it to a shop other than toyota B) Quote Link to comment Share on other sites More sharing options...
Leighcm Posted January 30, 2006 Share Posted January 30, 2006 A 2001 Celica could possibly be still under powertrain warranty, depending on exactly when your in-service date was. Most likely, a check engine light is for a powertrain issue, so definitely take it to a Toyota dealer first. One thought: the most common cause of a check engine light in newer-model Toyota products is because people don't completely close the gas cap. Did the light come on shortly after getting fuel? Make sure you always click the gas cap closed at least two or three clicks when you close to be sure this doesn't happen. Quote Link to comment Share on other sites More sharing options...
