Engine-Rough starting
cppeters
I have a new 2010 with a 4 cylinder engine. I've noticed that even when the oil level is just a bit below full, the engine sounds like it's going to vibrate itself apart when I start after sitting overnight, when, presumably, all of the oil has drained out of the engine. Doesn't happen after the first start of the day. The vibration is huge and the engine makes a loud clanging noise. When the oil is topped off, it's less, but still not smooth. Anyone else notice this and would using a heavier oil (currently 5w-20), especially in 90 degree weather, make a difference? Thanks
Charles
