Awner209 Posted May 21, 2010 Share Posted May 21, 2010 I have replaced the clutch stop switch, the ingnition switch , and starter, still no crank, it has powerjust won't tuen over Quote Link to comment Share on other sites More sharing options...
Leighcm Posted May 22, 2010 Share Posted May 22, 2010 Does it have an alarm? Quote Link to comment Share on other sites More sharing options...
humanoid Posted May 22, 2010 Share Posted May 22, 2010 Have you checked the distributor/coil packs? Quote Link to comment Share on other sites More sharing options...
Celicacrazy94 Posted July 5, 2010 Share Posted July 5, 2010 Funny that you would say that. No start on a 94, celica. I have a 94 myself and it was the ignition coil. it had spark, it was turning over but no fire. so i put probibly 300 bucks in parts to find myself at the coil under the distributor cap. My Spark was not "Hot Enough" also try jumping it. keep your battery connected and hook up to a truck or mid sized car. the 94 celica has 191psi compression and a 9:1 compression stroke/ Non interfearance engine if u have 7AFE. lemme know if that solved the problem. Quote Link to comment Share on other sites More sharing options...
twistednaustin Posted December 16, 2010 Share Posted December 16, 2010 Check all your ground wires very carefully i have seen this before that ends up being a bad ground wire. Quote Link to comment Share on other sites More sharing options...
