Jose Posted May 17, 2010 Share Posted May 17, 2010 I am looking for a manual for a 2006 Avalon. Does any one know were i can purchase one. You may contact me by email jmpineiro64@gmail.com. Thank you for your help.I am try to remove my hid lights, does anyone know how to remove them. Quote Link to comment Share on other sites More sharing options...
Leighcm Posted May 17, 2010 Share Posted May 17, 2010 You're trying to just remove the bulbs? You should be able to pull them out from the back of the headlight case...open the hood and look at the back of one of them. If they are actually HIDs, do not touch the bulb with your skin as you can cause them to burn out sooner. Quote Link to comment Share on other sites More sharing options...
Jose Posted May 19, 2010 Author Share Posted May 19, 2010 You're trying to just remove the bulbs? You should be able to pull them out from the back of the headlight case...open the hood and look at the back of one of them. If they are actually HIDs, do not touch the bulb with your skin as you can cause them to burn out sooner. Quote Link to comment Share on other sites More sharing options...
Jose Posted May 19, 2010 Author Share Posted May 19, 2010 Thanks For your help I will try it. Quote Link to comment Share on other sites More sharing options...
Lester Lugnut Posted August 2, 2010 Share Posted August 2, 2010 http://www.diyrepairmanuals.com/products.asp?cat=9584 Quote Link to comment Share on other sites More sharing options...
